メインコンテンツにスキップ
A fully-featured tablet for teens. The NABI XD Created by Fuhu inc. and was released December 2012.
3回答 すべてを表示
Nabi XD Black screen. Will not power on at all. Any suggestions?
The screen will not come on. When charging it goes from red and turns to green a couple hours later, so I'm sure charging isn't the issue. There is no way to reboot either since screen will not come on, I have tried that also. Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
Make sure you are using a Nabi charging cable, then try a different outlet, or try using your USB and connecting it to a computer.
If that does not work, it seems that your device might need a screen calibration. To do so, follow the next steps:
Temporarily remove the rubber case.
Hold the Volume+ Button and the Power Button at the same time to trigger a touch screen recalibration.
If the screen is unlocked you will see a message. Follow instructions and please don't touch the screen until the calibration process is complete.
If the screen still does not respond, try performing a soft reset. To perform a soft reset, follow the steps in here: https://www.nabitablet.com/support/artic...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My nabi tablet is changing to red and green and I moved it from place to place and its been charging for 6 hours what should I do
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
crazy4myphone さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 2,804
