メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
This tablet is 9.09" high, 6.21" wide, 0.34" thin, and was released on October 2nd, 2011. Its Model Number is GT-P7310.
10の回答 すべてを表示
tablet wont accept charge
Hi, I need help my daughter tablet dead & wont accept charge, so I open back cover disconnect the battery & reconnect but no luck, I measure battery voltage 3 volts
next step I did was disconnect battery & direct charging the battery for four hours ( I create modified one with alligator clips so that I can access to the positive & negative of the battery) check battery voltage 3.7, I let it charge for 2 more hours to make at least 4 volts but it stay at 3.7 volts,
I removed the charger and re connect the battery, switch power button on and galaxy tab display but its freeze in this mode and logic board start heating I can feel abnormal heat even in the display screen. I off the unit and did the normal charge & battery icon display but it wont accept charge . the final thing I check was remove battery connection and put the charger in normal way to check if the logic board still heating & its not, check battery voltage to terminal connecting to the battery 4.2 volt
I conclude that when my battery down to 3.2 volts it will totally dead
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Jhun Banton, this could be caused by a bad battery (even so it charges does not mean it will hold a charge) as well as a bad charging connector or a failed power management IC on the logic board. I would suggest that you start with the simpler things which is a battery replacement.
この回答は役に立ちましたか?
スコア 1
コメント:
Thanks oldturkey I will try to swap battery first before I buy a new one. I hope its only a battery problem. but I'm worried about the ic power management its too hot. Thanks anyway I will let you know after I try the battery first.
さんによる
コメントを追加
回答を追加する
Jhun Banton さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 726
