5.08mm T5 Torx screws
Do you sell just the 5.08mm T5 Torx screws for the 1st gen Surface? Kickstand is fine and does not need to be replaced, only need a missing screw.
Thanks
Try this search on Ebay "T5 Screws Screw Repair for HTC"
I ordered "10X Black T5 Screws Screw Repair for HTC Sensation SE Wildfire S EVO 3G Amaze 4G" and I am pretty sure they will fit.
Oh, tried contacting MS support and they suggested I replace the whole Surface at my expense as the warranty has run out. I needed 2 screws...
このアンサーは役に立ちましたか?
Michael did these work out for you I have same issue and MS are very silly and not at all helpful. Thanks Mike
Did the screws fit?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 2,740
