メインコンテンツにスキップ
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
154回答 すべてを表示
締切られた回答
Some part of screen are unresponsive after digitizer replacement
Broke my front glass so I had it replaced with new digitizer.
Now after the replacement few parts of the touch screen are not responsive while others are fine.
What could this be? Even when the old glass was cracked, everything was still working smoothly.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
It is most likely a defective part. Double check the connectors and make sure everything is tight. If any areas of the cable aren't making contact fully this can happen. If the connections are good then the part needs to be warrantied.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There are really only a couple things this could be: A bad digitizer or the connections not being made. Clean off the digitizer connection cable and clean the connectors with 99% or 91% IPA. Make sure to check the connectors really well for damage. There is something about the iPad 3's connectors that like to break.
As always: use plastic tools and take your time. If you don't see any damage and the screen is still flaky, you know its a bad screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 133
