Replacing the Inverter.
From looking at the troubleshooting guide it appears that I need to change the inverter. I see the step by step instructions on the display assembly. Is the inverter inside the display assembly ? the unit is an A1106
The inverter is in the display assembly.
Follow the Model A1046/A1095 guide to access it. It's the same procedure (we'll work on porting this guide over to the device page for your machine. Sorry!)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,332
1件のコメント
Could you give us a bit more information on your machine to ensure an accurate answer? The model number on the bottom of the machine would be ideal. Thanks!
Ben Eisenman さんによる
