メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
630回答 すべてを表示
締切られた回答
New front panel won't stay stuck
I've repaired many ipads now but on a number of them the glass doesn't want to stay stuck down. I've had problems with both the ipad 2 and the ipad mini.
I've tried different things such as using goof off to remove the old adhesive, double sided tape, and even reheating the glass once it's installed and putting weight on it to hold it down while it cools.
Any suggestions for this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Mike,
I struggled with iPads for a long time. Here's what I suggest. After removing your digitizer, use a metal sanding material(think scotch-brite) soaked in 99% isopropyl and scrub the frame surface until it's completely smooth. Then, I use a very high quality tape to apply it, I will link it below. Better adhesive is really the answer. I also find I get better results when I apply the adhesive to the frame first.
After laying down your digitizer, use some plastic clamps and clamp the 4 corners as well as one in the middle on the top and side. Two clamps will go on either side of the home button. Once it's under pressure, heat the screen and allow it to rest and cool for about 10 minutes. I haven't had a single issue after using this method. Also make sure you're getting your digitizer cables folded right. Hope this helps!
http://www.amazon.com/Tesa-4970-Tackifie...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 16
今までの合計 319
