メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
iPhone 5 Charges only at certain angles?
My Iphone 5 charges only when the lightning cable is pulled to a certain direction. It's the same way with two offbrand chargers. It works fine with a friend's OEM charger that came with their iphone 6 however. Both of my chargers worked fine for several months while I was on a trip, but have suddenly stopped working at the same time. I'm wondering if this is because of the IOS update that stops non MFI chargers from working? I cleaned out the port, no lint, and if getting a MFI charger is the solution, do I need to order off the Apple website or is there any cheaper solution?
Edit: Just checked friend's iphone 6 with my chargers, her phone doesn't charge with mine unless its pulled to the one side as well.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
I went to walmart and bought an Onn brand MFI certified charger, and it charges perfectly now. Perhaps both of the others just happened to randomly die at the same time? Oh well, its all fine now anyway. Not the charging port.
さんによる
コメントを追加
1 件の回答
If this ever happens, its typically a free, easy fix. I fixed one with a tooth brush. Cleaning out the charger port was just dirt.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,173
