メインコンテンツにスキップ
Sonyの15.5インチコンバーチブル型タッチスクリーンノートPC。
9回答 すべてを表示
My laptop touchpad multi-finger doesn't work.
Hi there. it's a couple of weeks that my vaio touchpad (Flip model) multi finger is not working. I tried to update the driver, but it doesn't work yet. Actually, i can't see any option for multi finer now. Is there any solution for that? When i connect a wireless keyboard (which has a touchpad), the multi finer function of keyboard's touchpad works properly.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
More info is needed to accurately answer this question, like did you upgrade the OS to 10 or remove any software but to start, I would uninstall and delete if option applies, any and all HID Touch & Sensory drivers from the system and reboot. Also, check the Sony site for driver checks and support solutions. If all else fails, do a system reset, with Windows 8 recovery media or on Windows 10 using the Recovery, Reset Settings, removing all data "as if to recycle the device".
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Behrooz Balaei さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 375
