Replacement of damaged cord possible
I have a microsoft trackball explorer and really like to get the damaged cord fixed as I loved this mouse , is it possible ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If the mouse is still working but the insulation on the cord is cracking you can fix it with Sugru. Otherwise if you dismantle the mouse it should be possible to chop off the damaged part and solder the good part of the lead to the board or the stump of the wires.
このアンサーは役に立ちましたか?
Here's a video of a painfully amateur technician tearing one down. https://www.youtube.com/watch?v=NWuBHRRU...
It's according to what kind of shape your current cable is in and where the break is. If it's close to the mouse just cut it off and solder in. Or you may need to splice it in if it has a plug receptacle. Or here's a replacement cable that might work for you: http://www.ebay.com/itm/High-Quality-USB...
Phillip has the right idea. What is Sugru? https://sugru.com/about
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 313
