メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
Where to find or buy bracket for isight camera
Lost the bracket for the isight camera in my MacBook 13" Unibody 2.4 GHz. Where do I buy a new or used bracket?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Andre - Do you still have your old screen? It will be glued to it.
The only way I know to get it is to buy a used screen if you can find one. The new replacement screens don't have it (at least that what I encountered of the few I replaced).
さんによる
Hey Dan, he did not ask for suggestions as to where he may have lost his old one. Nor did he ask to buy an assembly to dismantle. He asked specifically if anyone know where he could acquire a new or used eyesight camera bracket. You offered nothing that would help him locate one. If you do not know the answer to the question, please do not feel obligated to make up an answer.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I believe the part you've mentioned is only needed to align the camera to the front glass camera hole.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Yes, thats correct! +
さんによる
Frank Walk, What does the function of the eyesight bracket have to do with helping this person locate one for his computer. He did not ask what the eyesight bracket does, he asked if anyone knew where he could locate one. Although your answer is technically correct, it was not an answer that was any kind of solution to this man's problem. You may as well have told him what it was made out of or what color it was. Neither of those help him find one either.
さんによる
コメントを追加
回答を追加する
Andre さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 111
