Dryer won't start shows F-1 code.
The dryer shows F-01 when I try to start it. Is this a fuse issue? If so, which fuse?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
marksmonaco. the F01 indicates a failed electronic machine control board. First try to reset your washer by unplugging your dryer for a while. then plug it back in and see if you still get that error. If the error code returns after plugging the dryer then the electronic machine control board will need to be replaced. Take a look on here.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 14
過去 30 日: 57
今までの合計 21,437
