temp and lamp lights flashing
temp and lamp flashing lights on Epson 3010 projector
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Johnny Saltos,most common cause for that is a bad air filter. I'd start by replacing it
このアンサーは役に立ちましたか?
new filter,problem still
lemp red signal
If the filters new and the Fans are running at the normal speed , then its most likely ur ma inboard that needs replacement!
We have had a few of these units come with the mainboard problem!
Cheers
このアンサーは役に立ちましたか?
hey might there be fraudulent procedure in this?
my lamp was working just fine one day until this epson started complaining about how many hours Ive had it (3984 hrs). Now when I turn it on, it shines brilliantly for one minute, then the dumb projector shuts it off and has the lamp error light flash red.
This seems like a ploy to get me to spend money.
I even read somewhere that certain projectors send a signal to burn out a circuit on the lamp on purpose.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 12
過去 30 日: 49
今までの合計 1,377
