メインコンテンツにスキップ
Why is my screen dim?
I have replaced the inverter, and the inverter-eye sight cable, but to no avail. Is the problem the LCD, or is it the video card? Is there any why to replace a video card on this model? Or could the problem be something else? Also what is the other cable that is on the other side of the inverter? Could that cable be the problem? Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
did you check the ambient light sensor settings for the screen?
go to System Preferences-->Displays and see if the "automatically adjust brightness as ambient light changes" box is unchecked.
the "video card" has nothing to do with the brightness of the screen - and by the way - did you set the backlight to 100% ??
to answer the last question - no, i don't think that this could be a cable issue. if it's not a software issue - i would say that the CCFL bulb is faulty (since you already replaced the inverter)
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
How do I fix that? Is it the screen?
さんによる
did you check the other points ? if it's the CCFL bulb - you NORMALLY have to change the screen. but i would try to find a broken screen with a working backlight. surely you have to be careful - but i did this a few times and it works without a problem
さんによる
さんによる
コメントを追加
回答を追加する
martinjenn97 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,174
