One side of the headphones aren't working
How do I fix the headphones so both sides are working?
Cole Nagashima, you need to check a few things. start with the audio cable. Use a multimeter to check for continuity. Should the cable be okay, check the audio jack to make sure that all the wires are still soldered to it. If that checks out ok, check the wiring continuity from the audio jack to the non-functioning driver (speaker). The repair will depend on what needs to be fixed.
このアンサーは役に立ちましたか?
Just check the cable with a resistor meter. if everything works out take out the side of the earphone that doesn't work. decoder the earphone and replace it
このアンサーは役に立ちましたか?
I checked the wires going out from where they split at the 3.5mm female jack.
The left side is good, but 1 of the two cables going the the right side isnt receiving any current.
What should I do?
このアンサーは役に立ちましたか?
Eeem... guys? How do you fix both parts?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 8
今までの合計 15,140
