メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
iPod Touch won't turn on or respond at all
I've had my Ipod Touch 2nd Generation for about a year and a half. Recently it stopped working completely. Does not charge or connect to my computer. Does not turn on or restart with home and power buttons. I think it is the battery and fortunately I have a two year warranty. Unfortunately my Ipod Touch had most likely taken water damage (even though it has never been effected by this, it has never been submerged in water but was in my pocket during rainstorms) and has a small crack in the screen (again neither of these things should have broken my Ipod because they both happened weeks or months before this problem). What should I do in this situation? Go to an Apple store and risk voiding the warranty or something else. I'm kind of in a a bind.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
forget about voiding the warranty - that warranty is gone since the first raindrop hit the fluid indicator.
the only thing you could try is to disassemble the ipod and check the logic board for fluid residue (white/greenish stuff)
if you have a multimeter, measure the battery - if it has less than 3v - the ipod will not be charged or start
use the logic board guide when you open the ipod.
another thing about fluid damages - it can take month until something blows up.
had one on my table a few days ago (beautiful 32gb version) - they told mthat there was an incident with beer, i tiold them to bring it in - but not - it was working - until a week ago.
now it's simply toasted
so don't hesitate and open it.
if you find fluid residue - clean it with isopropyl alcohol (>90%) and a soft paintbrush - don't forget the connectors!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hey Markus, if it is below 3V would that mean that the logic board is damaged? Im assuming so but I just wanted to make sure.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
sometimes the battery is so old, tired and fed up that it loses the ability to charge or be charged. Less than 3v means that this battery is beyond usefulness. You may bump start it but in the short term you will become fed up of charging it every hour. So, swap it for a lovely fresh new battery. The fact that it has got to less than 3v is not so much an indicator that the logicboard is bad at all. Swap your battery and then reassess/reassemble. (BTW not all batteries that you buy will be manufactured yesterday. This is an older model so you may receive a battery that has been shelved a while..have just replaced battery x3 before I got a good one!)
さんによる
thx pollytintop - great answer ;-)
さんによる
コメントを追加
@pollytintop, my ipod gives me a message that it needs to be charged when it reaches 20% (0.74v). I don't understand the statement "Less than 3v means that this battery is beyond usefulness." Can you explain in a little more detail.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
the 20 %is of your charge not your voltage. 800mAh=100% 20%160mAh
さんによる
コメントを追加
my ipod touch is not working becuse i droped in water oer its not turning on ether
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matrix813 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 14,549
