home iPhone6 home button replacement will id still work
if i change my home button on my iphone will the id finger senor still work with new home button
No, Touch ID will die immediately and if you try to restore/upgrade iOS, the phone dies altogether.
このアンサーは役に立ちましたか?
Hi,
Try a hard reset ,
Where you press the on/off switch and home button .
It has worked for me every time I have had the issue.
Hope it helps.
Thanks
このアンサーは役に立ちましたか?
If you replace it with a home button that has a touch sensor in it, then yes. Why are you changing the home button, is it broken?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 100
