camera went in salt water
went smimming with my camera in my pocket . batter will not charge,i dont know if the camera works?
Sounds like a headline for your next blog post "6 year old camera went in salt water, wasn't worth trying to fix, then went for recycling"
hopefully your pictures are saved to an sd card or otherwise backed up, I'd hate for you to lose vacation pictures but salt water is just about the nastiest thing to drop your electronics into. On top of that, the lenses in the camera are nearly impossible to clean so if there is water there, you will never take a clear picture with it again.
The cost and work of repairing the device more than likely exceeds its value.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 84
melvao54 what are you going to do? Fix it? Get rid of it? Just checking to see if you can do anything with it? If nothing else use these guides to take a closer look.
oldturkey03 さんによる
