wifi is greyed not working after restore
ipad air 2 wifi not working after replacing lcd and restoring
この質問は役に立ちましたか?
Hello,
This wifi grey for iPad 95% due to malfunction of wifi port/board "''something that connect the wifi cable network"it is small board in the main PCB. change this port/board and your problem solve like forever.http://postimg.org/image/tkrzc35nr/
コメント:
where can i find this port/board?
@nimesh you need to get it from your local repair shop that have a spare for this 1. not sure if there any china supplier sold this.
by Wan Syakirin
You most likely cut the wifi cable upon removing the digitizer. This can be very difficult not to do. Pull the digitizer back up and inspect the cable that is screwed to the frame to the right of the home button. See attached picture for location.
コメント:
You can't repair greyed out wifi with a new antenna, it's like replacing the tires when your car's engine won't start.
by Tom Chai
過去 24時間: 1
過去 7 日: 7
過去 30 日: 72
今までの合計 3,356
