メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
締切られた回答
rear camera and flashlight not working front camera behaving oddly
Hello! After replacing a cracked LCD on my Iphone 5S everything worked perfectly. The front camera worked well right after the replacement. The rear camera aswell. Didn´t check the flash. Because im tired of fixing lcd´s I got the most massive case I could find (you even have to screw it secure with 6 pentalobe screws).
After assembling the case the rear camera wouldnt work at all (black screen, photo app crash), the flash wont work anymore (cant even turn on the flashlight, the symbol is unchecked whenever i release my finger from it, no light even when holding it down), and the front facing camera behaves oddly. It inverts all pictures.
I dont even know what caused this error. I doubt all 3 parts malfunctioning at the same time and dont know how to fix it. I hope you know how to help me!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It is likely that the back camera connector came unplugged or damaged when you were changing the LCD. Time to take out all those pentalobes and check the connectors.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
first of all, thanks for your answer brian! the connector would explain the back camera (and maybe the flash too?), but why would the front facing camera behave so oddly?
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,780
