メインコンテンツにスキップ
2011年9月28日に発売されたKindle 4です。
75回答 すべてを表示
Why wont my kindle Charge
Hi,
My kindle has been out of use for a while now. Last time I used it it was faultless. I have pulled it out to load a book and it is showing the charge picture on the screen. When I connect the charger it illuminates with a orange light but then after 30 seconds changes to a green light. After being on charge for a full night it is still showing the charge picture on the screen and it will not turn on. HELP
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメント:
tried 2 different chargers and it will not accept a charge
さんによる
I finally woke it up and it is now charging. Thanks for the help.
さんによる
コメントを追加
2件の回答
選択されたソリューション
danandlozza04, if your Kindle after a long time charging still does not take a charge, then it is possible that your battery has been discharged below its threshold to take a charge. This would require changing the battery. Here is a decent video about the replacement. The battery is available at multiple places of your choice.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Try leaving the power button pressed for a LONG time. Sometimes kindles have to be reset. If 90secs have passed and you don't see anything different then let us know. Post your results either way :)
このアンサーは役に立ちましたか?
スコア 1
コメント:
I have held the power button until it blinks twice then shuts off again - the screen still shows the battery icon - this is after I have charged all night - what gives?
さんによる
コメントを追加
回答を追加する
danandlozza04 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 114
今までの合計 8,755
