メインコンテンツにスキップ
Canon製プリンターの修理情報です。
427回答 すべてを表示
Bad Color prints - Refilling, Cleaning helpless.
Hi,
I had Canon Pixma MG3570 Printer which is multi-functional wireless printer.
For the first time the cartridge got empty. So i refilled the Black & Color cartridges upon emptying.
Since then, I have problem in printing color pages but only black photo copying works fine(not gray-scale prints which have random faded/deviated colors or stripes upon printing).
The sample test print (pattern & alignment check) are included as attachment.
I have emptied & completely cleaned color cartridge with water & dried & refilled. Even though same problem continues.
Please Help me in rectifying it.
And also i would like to know availability of:
1> Any reset software are for this printer (like MPTool or any other).
2> Dis-assembly & assembly manual or video.
3> Any other immediate maintenance required (like waste ink pad cleaning or ...)
Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
It looks like the print heads are partially jammed. Cleaning them should resolve your problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thank you JohnnKlein14 for the reply.
May i know the cleaning procedure for this cartridge (CL-741).
Do i need to cut & open this cartridge to clean( is it sufficient to clean with water or need any solution particularly).
Which is the best way to clean it.?
Precautions, if any ... to keep in mind before doing this.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
A1Star did you ever resolve the problem with your 5320?
さんによる
コメントを追加
回答を追加する
a1star さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,165
