difference between the LCD connector on iPhone 5s and iPhone 5c?
got a few pins broken off an iphone 5s and i have an iphone 5c for parts. im wondering if i could desolder the connector off the 5c and solder it to the 5s.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Jake, they are not compatible. The 5C uses a AA22LB-P 28 contact connector (14 on each side) and the 5S uses a BM15AP(0.8)-22DS-0.35V 22 connector (11 on each side). You will notice that the 5c is a larger connector,even by looking at the images provided to you.
このアンサーは役に立ちましたか?
Thank you. guess ill just wait the two weeks then.
also, where do you recommend getting these parts? i use ebay but id like to know is there is somewhere more creditable. maybe mouser?
I checked mouser and digikey and neither one seem to have those. this may be a case of getting it where you can
Very detailed info. Thanks so much for this!
The iPhone 5C and iPhone 5S appear to have the same LCD connector (flex cable).
You may want to attempt it if you have the part readily available.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 123
1件のコメント
Since you have both, why don't you compare them? I would've answered if I knew the answer. But that's what I would do to find out for myself.
Rany さんによる
