Plugged OnePlus into iPhone power adapter!
I plugged my OnePlus into the iPhone power adapter by accident, and now it does not charge my One Plus. Please, what can I do to fix it?
oh......
I think it can only replace the tail inserted(usb尾插板/充电板), but I'm not sure if there is a short circuit inside the machine ...
good luck
このアンサーは役に立ちましたか?
Do you mean that you plugged an Apple Lightning cable into your OnePlus One? If that is the case, and the port is indeed damaged, you can buy a replacement port. The port is connected to the motherboard at the top of the phone with a flex cable that runs below the battery a bit of tape.
See step 16 on the teardown.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 136
