メインコンテンツにスキップ
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
23回答 すべてを表示
cranks but does not start, suspect immobilizer, how to repair?
car cranks but wont start, found mouse cut the wires inside dashboard. this wire seems connected to TDS. please help me solve the case.
thanks.
Basudev.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
最も参考になった回答
probably security system wires were cut by mouse which either disconnected your fuel motor power or current being supplied to spark plugs
if these two things are fine then you must check Camshaft position sensor & Crankshaft position sensor for malfunction
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bashudev さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 739
