What do I do when only half of my LCD is working?
When my LCD is on only half of the image is showing on the screen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It sounds like the cable connection is lose. Either that, or your screen is damaged and needs to be replaced. You should try opening your tablet, and removing the screen. Reattach the screen and make sure all the cables are attached to the motherboard. If the problem persists than you will have to replace the LCD. Try using the guide below.
このアンサーは役に立ちましたか?
This could be caused by 2 problems.
1. If you replaced the LCD it could be the connectors arent fully plugged in.
2. The LCD is going bad and you need to replace it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 271
