How do I replace the power button and cable?
Or can I get away with just taking off the cover and accessing it from there?
Check this out
このアンサーは役に立ちましたか?
Okay I checked it out and couldn't find the answer to my question
You need to unscrew the back plastic part. The power button flex is glued to the inside of it. You can't get away with only taking off the snap on cover. Hope that helps a little more
Any tips on how to connect/disconnect those tiny wire connectors. I'm just butchering them.
Which ones exactly?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,635
