メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
4057の回答 すべてを表示
Best way "remold" frame?
Hi, as everyone know, iphone 5 serie frame is very very fragile.
i just changed 5s lcd to a client and his frame was very very broken so when i clipped the lcd to the frame, lcd broke....
reason, the metal frame is very deformed and blocked some place where lcd going to.
so, i take metal blade and scrapped all the frame where it was broken, finaly after 45 min, i was able to put new lcd without damaging it.
so what is your best tips/way to "remold" frame to be able to put the new lcd ?
thanks
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
The Essential Toolkit
コンパクト版iFixitキットの中で最も利便性の高いツール
ショップを見る
ショップを見る
3件の回答
選択されたソリューション
If the housing is dented, you can use a round edged metal spudger or flat head screw driver and a hammer to knock out the dents, you can also file it away and give it a smoother edge.
Or, you can also use a tool called gTool, expensive, but performs really well in pulling dents out and make it look pretty good to.
この回答は役に立ちましたか?
スコア 3
コメントを追加
I repair thousands of devices a year. Yes, I have a file set in among my tools but I've only used them a handful of times. Rarely should you have to resort to removing metal from a device.
I've also got a small brass hammer, various screwdrivers and spudgers I like to use to bang the phones and ipads back straight in addition to a set of G-tools. You should be able to straighten 95% of the phones you come across without removing metal. I've even seen people get the idea they need a dremel tool to hack at ipad frames with. I assure you, a dremel tool has no purpose in the world outside of your garage and shouldn't come anywhere near a cell phone.
この回答は役に立ちましたか?
スコア 1
コメントを追加
Thank you , will try the gTool :)
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Phonetech93 さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 140
