メインコンテンツにスキップ
Apple iPhone 5cは2013年9月10日に発表されました。このデバイスの修理は前モデルと類似しており、スクリュードライバーとこじ開けツールが必要です。GSM か CDMA、8, 16, 32 GB 、色は白、ピンク、黄色、ブルー、グリーンがあります。
1225回答 すべてを表示
Possible chip damage? Phone reboots every 2-4 minutes.
Hello,
A customer has brought me an iPhone 5C for power issues. Upon opening the iPhone I can see that the screen has been previously replaced. Phone appears to be clear of water damage.
The phone reboots every 2-4 minutes, either plugged in or not plugged into a charger. Replacing the battery makes no difference and restoring the phone through a DFU does not fix the issue.
I have managed to locate some board schematics but have not a clue which area and chips to look at.
Hope you can help.
Thank you kindly.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
same problem- you ever find a solution?
さんによる
Unfortunately not yet. Definitely think this is chip related.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Bad battery or missing filter near battery connector
このアンサーは役に立ちましたか?
スコア 3
コメント:
Thank you for your reply. I have tried a few batteries with the same result.
What am I looking for in terms of these filters?
Board examination is completely new to me.
Thank you!
さんによる
I have same problem with iPhone 5c. I have three missing components. As in the picture at the top FL11 and the two below it. Jessa can you tell where I can find those replacement components. I have olso iPhone 4 donator board. In iPhone 4 chemantics there are FL11 but it still missing from every iPhone 4. There are many Fl components in iPhone 4. Is that same thing If I replace Fl11 with for example FL23?
さんによる
コメントを追加
The Filter you are looking for is FL11 and is extremely small. I've attached a picture with the filter circled in red.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
check for any components knocked off around the battery connector. unplug battery and charging port to inspect. microscope is recommended
このアンサーは役に立ちましたか?
スコア 1
コメント:
Thank you. I will inspect under a microscope. Upon eye's view, the components seem to be okay when compared with another board.
さんによる
コメントを追加
回答を追加する
zentech さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 196
