Constant Issues With Screen Integrity After Screen Replacements
Hi. I've been having some issues with screen replacements on the Z3. When I fit the new screen it never truly sits properly. I've been using the pre cut adhesive strips but these don't seem to be adhering the screen sufficiently, especially around the sides meaning that the screen is becoming weaker due to it not sitting flush.
I'm wondering what adhesive you guys use? I've resorted to buying the full screen/frame assembly but would like to avoid the extra cost if possible.
Cheers in advance.
この質問は役に立ちましたか?
3 件のコメント
Did you make sure to completely remove adhesive around the perimeter of the phone body?
Tyler Momberger さんによる
Yes. It's been fully removed.
James さんによる
I've just replaced three Xperia Z3 LCDs and am having the same problem. I think that part of the problem is that on this phone the screen holds the spring loaded ear speaker down, so the speaker is always pushing against it. I've tried several different tape/glue combinations and none have been as good as I'd like them to be. If anyone has a good source for precut Xperia adhesive I'd like to know to!
Johnathan George さんによる
