メインコンテンツにスキップ
Samsung Galaxy NexusはGoogleの最新デバイスであるNEXUSモデルと同じグループです。HD Super AMOLEDディスプレイにカーブしたディスプレイ、そしてAndroidバージョンは4.0 Ice Cream Sandwichです。
I dropped my phone & now the screen shows black
I dropped the phone while in a rubberized case with a plastic cover, and the screen is now black. The phone still works, but I can't use it because the touch screen is unresponsive & I can't see any of the content. How can I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
You may want to disassemble the phone enough to be able to check its connections on the motherboard. It is possible that the displays connection was loosened when it was dropped. Try reseating the display's cable connections and see if this fixes the problem. You may also want to look over the cables and other parts for damage.
If reseating the connections still leaves you with a black screen then may have broken the LCD in the display. To fix this would require a new LCD or new display assembly(LCD ➕ digitizer) if the digitizer is damaged too. The digitizer is the part of the display that is responsible for sensing touch. Hope this is helpful.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If I wanna fix it myself how much would the LCD digitizer cost for my Samsung J2
さんによる
コメントを追加
回答を追加する
Hetesh Patel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 1,833
