Toshiba Satellite C750D Please help
I have a Satellite L750D , how do I do a factory reset ? thank
Hello Frase
See if this recovery procedure will work for you.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
-> Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 171
