メインコンテンツにスキップ
Amazonから発売されたKindle Fire7インチのタブレットの改良モデルで、1280x800 HDディスプレイを搭載しています。2012年9月に発売されました。このデバイスの修理は直接パーツにアクセスできます。
101回答 すべてを表示
Troubleshooting info or Electronic Schematics for Kindle HD 7
Does anyone have troubleshooting info or electronic schematics for a Kindle HD 7? The volume icon keeps popping up with max volume and you can't close it without squeezing the case or bending it. I'd like to be able to understand how the fool thing works and some testpoints to identify the bad component rather than just replacing parts until I hit the right one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
It sounds like you don't really need a schematic ,hopefully you don't. It also sounds like your case is at fault for the fact your having to bend and squeeze the case to do what you want. I would use a teardown guide and see if something is lodged or blocking your volume buttons a little arranging and engineering more than likely will fix the problem.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I tore it down, removed the volume control button. Now it doesn't work at all. I shake too much for this detailed micro work. How does that go now? If it ain't broke, take it apart and it will be. Just need to get some copper tape and a soldering kit. I think I should be able to fix it. Either that or I'll buy a new one and use this one for parts. Haven't decided yet. It was a learning experience as the saying goes.
さんによる
you desoldered it ? copper tape? are u planning on doing some jump work ? Can you post some pictures of what's going on?
さんによる
The black wire off the battery was not crimped correctly and fell off. I soldered it back on but it's a globby job. When I peeled the copper tape back, it tore, of course, and there was a screw under another piece. It just doesn't look "factory correct" for my tastes.
さんによる
コメントを追加
回答を追加する
phudson38 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 633
