Why my laptop is not producing sound?
i could not play songs and videos on my laptop. it is showing bad sound drives. how to rectify the problem?
please help in installing my sound drives. i am having net connection with my laptop.
when i am starting the system sound is not coming for audios and videos but when i restart laptop sound is coming and it is happing every time.please tell me the correct solution
このアンサーは役に立ちましたか?
a good place to start is the home page for the device in question if your able to find the exact driver wahoooooo install reboot and all should be well. if your manufacture doesn't give out drivers down load a utility to give you exact system information i use Everest only because its free this program will identify the make and model of the hardware within your lap top with this info you can then go and search out the driver on the net i hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,795
I have a problem in sound "no audio output device is installed"this my problem i don't no what to do
Mohamed Elkholy さんによる
