2012 toro lawn mower sat in garage 2 months will not start
checked spark plug and changed gas still wont start. does anyone know what could be the cause.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
this could be a gummed up carburetor or dirty fuel lines as well as a stuck float valve. Squirt a little bit of gas into the carburetor and then try to start it. If it does, you know that you issue is fuel related. Remove your fuel line and clean those, make sure they are not kinked, You may have to clean your carb. Let us know what model your Toro is and what engine model it has.
このアンサーは役に立ちましたか?
the model number is20370 the engine is kohler xt6.75
can you tell where the carburetor is located
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 164
