What is up with my screen?
hi could you tell me what is up with my phone its a samsung s5 i dropped it yesturday and my phone screens gone all fuzzy i carnt see anything on my screen but the touch is still there?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Faulty Lcd, will more than likely need replacing. :-)
このアンサーは役に立ちましたか?
only had the phone a few month brand new from shop there is no crack on my screen and the buttons are lighting up and the touch is still there :/
Usually when a phone is dropped, it cracks only the glass (pretty much the lens for the lcd). It sounds like it fell hard enough that it made the lcd malfunction. If there is no visible crack on the lcd, it could just be the wiring inside. This is usually not the case though. You'll have to buy the lcd and glass combo online. I think they're cheapest on Amazon.com at around $130, last time I checked. As for the touch still working, there is another part called the digitizer. This is what senses your fingers. It's a lot more flexible and resilient then the lcd and glass. Thankfully, that also extends to impact protection. :) Hope this helps and good luck!
このアンサーは役に立ちましたか?
More flexible and resilient THAN the LCD. More THAN, less THAN, rather THAN, etc.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,676
