My Black color in screen turns into green after a while
I open my mac and after 5 to 10 min the black color in my screen turns into green . Is there any solution?
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
This could be the LCD failing or the Graphics chip on the board failing.
このアンサーは役に立ちましたか?
MCP79 never partially fails, LCD connector not plugged in properly.
このアンサーは役に立ちましたか?
Can you show me where is that connector.
So how can i fix it. For motherboard replacement ask me to pay 700euros and for screen 900. Its too expensive and they are not sure if the problem will be solved.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 98
2 件のコメント
What happens when you use an external display? If it doesn't show up on the external you know the internal display is having problems.
Dan さんによる
I'll try it...... using an hdmi cable.
Peter さんによる
