installing ram on Dell Inspiron Duo
can ram be installed into this particular laptop?
Vanessa Marshall, not above the original 2GB . The max RAM Is 2GB and is limited by the CPU, the Intel Atom N550 only supports a max of 2GB.
このアンサーは役に立ちましたか?
The RAM can be replaced, however. If for some reason there's a problem with the ram that's installed, you will be able to replace it. But like oldturkey03 said, only with another 2GB stick of RAM.
このアンサーは役に立ちましたか?
Vanessa, if you would like step-by-step instructions to guide you through this process, here is a link to the RAM replacement guide. Hope that this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 238
