メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
Also known as Sony Xperia Z1 Honami, Sony Xperia Z1 C6902/L39h, Sony Xperia Z1 C6903, Sony Xperia Z1 C6906, Sony Xperia Z1 C6943. Released September, 2013.
65の回答 すべてを表示
Is it possible to change motherboard?
My Xperia Z1 is presenting issues with the motherboard, can I buy a new one and replace it? I saw one in ebay but the region code was different, does it matter? What should I consider before buying a new motherboard?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Hey Antonio, it's possible to do a motherboard replacement of your device. Follow this video (restart to replace), it should give you a good idea and a technique. You can purchase a motherboard from eBay but here are some things to consider:
-Is the seller giving a fair return policy?
-Does the seller have a good reputation?
-Has the seller sold products like this with good reviews?
-Does the product have good reviews?
-Are you purchasing the correct motherboard and are you sure that the details of your phone match with the details of seller?
Something like this would be a wise decision. Be careful when shopping.
EDIT
-The dis-assembly video I showed you works for the model you have.
-For some reason, if you are unable to find the certain motherboard for your device, I was able to find this and this. The tips stated above can be applied to this website as well. This website seems to state that there is a six month warranty and one of the sellers stated that is the product is defective within the first three months, they will replace it.
-Let me know how it goes.
この回答は役に立ちましたか?
スコア 3
コメント:
that's for a Xperia c6906, mine is a c6903. Thanks for replying iApple
さんによる
Hey Antonio, thanks for accepting my answer. You can check out the edit in my post for more info on your certain model's motherboard.
さんによる
コメントを追加
Hi can i l39t model motherboard on the l39h model? thks
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Antonio さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,165
