メインコンテンツにスキップ
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180回答 すべてを表示
Big bold vertical white lines after screen replacement
Hey I have a G3 and I recently replaced the screen with the entire frame.. After installing it worked fine. But after five minutes the screen started to show me a bunch of thick white line going from one end to another of the screen. Would you guys have any idea why this is happening ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
最も参考になった回答
Bad connection to the daughter board on the bottom of the assembly
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I have the same problem after I dropped the phone, hopefully I just have to check the connections on mine. Thank you very much for this answer, you probably saved me from repurchasing the screen for nothing!
さんによる
コメントを追加
回答を追加する
blockboy21814 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 759
