メインコンテンツにスキップ
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
243の回答 すべてを表示
4Gb Internal memory card port
First off my 4gb internal memory is corrupt. I've seen numerous teardowns of xbox s consoles. They all have the removable/replaceable Internal Memory Card (IMC) and male connector slot on the mother board. I tore my console down, to my surprise no IMC nor is there a connector attached to the mother board. I've now noticed that all teardowns I viewed were glossy black consoles, as for mine its glossy white. Official name of my console : Xbox 360 special edition Skylander's adventures. Is there any knowledge you can share with me about the diffence between the to mother boards. Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
2件の回答
Xbox 360 slim when it came out had the re moveable 4gb memory then they changed it in 2011 or 2012 to were they are fixed too the board.
この回答は役に立ちましたか?
スコア 0
コメントを追加
This is not always the case. The Corona version of the motherboard has an integrated NAND chip that cannot be removed without specialist soldering equipment. The earlier versions of the Slim do indeed have a sisterboard that can be pulled away from the socket.
http://www.jpcomputers.co.uk
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SimplyBuilt construction さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 24
今までの合計 1,330
