Fell in the pool
My phone fell in the pool and it still charges and it gets hot also no screen display what to do?
Roderick, treat it like you would any other water immersion. The very first thing you want to do is to not try to restart, sync or otherwise try to use the phone. This may further damage your phone. The next thing to do is to clean it. Disassemble your phone using these guides Then clean it with +90% isopropyl alcohol. Follow this guide , and even so it was written for a Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate.
このアンサーは役に立ちましたか?
Most likely there is corrosion on the board inside the phone. It's possible to maybe fix it, but most likely the damage is already done.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 80
