メインコンテンツにスキップ
2014年9月19日に発売されたこのiPhoneは4.7インチのスクリーンサイズでiPhone 6 Plusの縮小版です。
4872の回答 すべてを表示
Phone won't power on after home button repair
I had an iPhone 6 that was dropped in water. I had no hopes of it ever working but after drying it out, taking the logic board out, and cleaning all corrosion, it powered back on like new! However, the home button was unresponsive because I forgot to clean the contacts for that specific part. I powered down the phone and cleaned the home button contacts. When I tried to power the phone back on, it was completely unresponsive. What could have possibly went wrong after messing with the home button to cause the whole phone to stop working? I tried a hard reset and iTunes will not recognize my phone. I checked the battery terminals and everything looked ok. Is the battery maybe bad? Any suggestions would be great!
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
Did you try reseating your battery and charging dock connector on the board? CAREFUL, they are fragile.
による
コメントを追加
1回答
選択されたソリューション
Hey Eddie, it could be a possibility that your battery is dead. I'd recommend that you dis assemble the phone and clean the device with 99% isopropyl alcohol and clean it with a soft brush just like this guide shows. If it still doesn't work, replace the battery, it may have gone faulty.
-Let me know how it goes.
iPhone画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
iPhone 6 バッテリー画像
ガイド
iPhone6のバッテリーの交換
難易度:
普通
15 - 45 minutes
この回答は役に立ちましたか?
スコア 1
コメント:
Always replace the battery on any device that was submerged. The batteries do not tolerate any liquid if exposed.
による
コメントを追加
回答を追加する
Eddie s さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 104
