I'm having problems with the DVD rom
when I write CD /DVD it doesn't end the disc!
You only need to unscrew a pair of screws and then pull the DVD unit off. Then put the mounting brackets in the new unit and attach it to the laptop.
Be sure that both unit have the same connection technology, IDE or SATA.
Search in this web for a DVD replacement manual. It is a quite standard procedure so any guide will be usefull.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 138
I want to change the DVD rom and I need a tutorial for it.
Thanks
Cristian Secara さんによる
