Why will my lap top not power up
my lap top does not light up at all.
i have checked the charger ok
i have tried without the battery connected stll no lights
what should i try next
Hey Kevin, you should first confirm if the computer works at all. Did you try to boot your computer through BIOS? I believe that pressing the power button and then F12 boots up BIOS on this computer.
If that doesn't work then remove the battery and power adapter, then press on the power button for about a minute. Connect the power adapter and then turn it back on. If it works, put the battery back on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 927
