How to change screen?
I had an accident, and drop computer and want to change screen, any idea how?
thanks
この質問は役に立ちましたか?
thanks
この質問は役に立ちましたか?
The Product End of Life Disassembly Instructions provide instructions on page 2 and 3 on how to disassemble the computer. The Upgrading and Servicing Guide provide instructions on removing user replaceable parts(e.g stand, memory, hard drive).
You can use the HP Part Surfer to find the part number for you model by entering MS225. This will bring up several product numbers. Select the product number that matches your model.
You should be able to find the LCD and its part number under Display. If you can not order the part number through the Parts Surfer, you should be able to contact an HP Authorized Parts Partner.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 452
