メインコンテンツにスキップ
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
254の回答 すべて表示
Kenmore Elite HE3 Gas Dryer not heating
Hello,
I have a Kenmor Elite HE3 and the dryer isn't working properly. The dryer flame will ignite come on for about 5 mins and then turn off. It will never turn back on again. The drum turns perfectly fine. I did a continuety test on all these items listed on the repairclinic website: http://www.repairclinic.com/RepairHelp/H...
All the parts seems to work fine following the steps of the test. Is there anything else I can try? I really hope it's not the electronic control boards.
Please help!
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
My dryer goes on but does not give any heat, how do you fix it. Burner doesn't light
による
Sharon, this is a different issue, try posting your own question.
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
最も参考になった回答
I appreciate this answer is a little late, but it may help other users with the same problem.
My Kenmore dryer would ignite for the first cycle but although the igniter would heat up for the next cycles, no gas was released. I replaced the coils to no avail. I than replaced the igniter because some internet advisors suggested that the igniter may not be working optimally, this did not fix the issue. I purchased a used gas valve and fitted it, the only difficult part was getting the incoming gas pipe to release from the threads on the existing valve. I ended up heating the valve a little around the gas pipe and the threads finally turned.
The replaced gas valve worked perfectly and the dryer has been functioning perfectly now for 2 weeks. Being a tinkerer I took apart the replaced gas valve and the found the main piston, which sits inside the solenoid tube was covered in black soot like some of the gas had ignited in the valve. I believe the soot was affecting the operation of the solenoid and the first valve was not opening.
この回答は役に立ちましたか?
スコア 1
コメント:
Thanks so much for your input on this. You have no idea of how many people look at these old questions. Just my answers get a million and a half hits a month. So a lot of folks are looking ;-)
による
コメントを追加
回答を追加する
burtonrider06 さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 575
