compatibility issues with my hp G60
i change my hp G60 operating system from windows Vista to windows 7, since then i have been unable to install some programming languages such as C++, visual basic 6.0 etc
この質問は役に立ちましたか?
この質問は役に立ちましたか?
When you upgraded from vista was it a clean install or did you lay the new over the old system.Its always best to do a full format and do a clean install, vista can reach up from your past and haunt you if you don't. Did you ever have problems running basic 6 on vista it works best on windows xp and the way around it is to install a virtual machine of windows xp and run it from there. Are you familar with VMware it works great there.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 79
