Screen glass cracked, Do I need the full display assembly?
The touch works fine, only the glass is cracked, what should I buy to fix it ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hadi Alkhamees, the assembly is fused together. Unless you have an LCD separator and the ability to properly fuse the parts together after, replace the complete assembly Here is the guide for it. The other way is to send it off and have Apple repair it. Complete repair by Apple for $109.
このアンサーは役に立ちましたか?
Hey!If touch screen is cracked You should buy the touch screen replacement, if LCD screen is for some reason cracked must buy LCD replacement :)
このアンサーは役に立ちましたか?
The front glass is cracked only, I can use the phone with no problems. Can you give me a link for the required part ?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 85
