メインコンテンツにスキップ
シンプルな35mmマニュアルフォーカス一眼レフカメラ。 型番X-370。
26回答 すべてを表示
Film advance lever stuck
The film advance lever won't move more than 1/2", how do i troubleshoot this problem? Does it have to. Have film in it to advance? Does it have to have the batteries in to have the advance lever move?
Herb
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Hi Herb, I used to work on dozens of the x-370's. The problem might be the shutter is already advanced and the shutter won't release because of a bad capacitor on the bottom of the camera. If you remove the bottom plate you will see a small flexible circuit with a little black can soldered to the flexible circuit. That is more than likely the culprit. So i would replace that and make sure you have a good battery to try it out. If thats not the problem you might have an issue with the film advance gearing which requires replacing and timing the gearing to the shutter assembly.
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
Just opened my x-300s up and the connections to a black barrel looking thing look corroded. Is this the culprit? Sounds like you called it spot on.
さんによる
Do you know where the specs of the capacitor are listed? Would save me a lot of digging. Just thrifted a x370 and ran into the same issue. took the bottom off and it looks like the capacitor is corroded on one terminal.
さんによる
コメントを追加
The manual for the X370 says that when the battery is discharged (dead) that the shutter is locked. Replace the battery and the shutter will release and the film advance lever will operate. This is an electronic camera and you must have a good batatery in it or it will not work.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Mine has brand new batterys and the film advance leaver won't release why and I have the Minolta x300s
さんによる
did you find a solution? just bought the same camera and i have the same problem
さんによる
コメントを追加
回答を追加する
Herb さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 55
過去 30 日: 222
今までの合計 35,585
