モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
386の回答 すべて表示
My screen has no backlight
Excellent write up, Im having the same issue, screen sometimes comes on but most of the time it stays off. Once every 100 times after restarting does it come on.
I'll have to check this out, thank you!
Update
I've been trying to track the issue down to the lvds connector but due to the lack or my knowledge and a visible gpu on this motherboard it's gotten to the point where I can't track the issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
最も参考になった回答
I would have an issue tracking it too since Apple hasn't used LVDS on these models for three years now.
Is your problem intermittent PICTURE or intermittent BACKLIGHT? Caused by water, drop, power surge?
Don't even bother checking backlight fuse on newer retinas as it is always good.
You could start checking voltage on both sides of L8300. Then voltage on pin 1 of the LCD connector, which uses displayport, not LVDS. Do we have no backlight, no image, LCD not detected because of issue in DDC circuit, LCD detected but not powering on because that little POS U8300 they put right by the vent got water on it?
Next thing to do is measure and report back findings.
この回答は役に立ちましたか?
スコア 2
コメント:
Sorry for describing shi* without doing much research. I'm getting intermittent display, back light is ok.
Will report back tomorrow with the readings I'm getting. Thank you!
による
zzz,
I'm reading 5V on both sides of L8300, and 38V on pin 1 of lcd connector.
I have a boardview and schematic, but im new to reading schematics....viewing a few videos and doing some reading on how to read it.
による
5v when you have video on the screen or 5v when you have no video on the screen?
による
5V when there is No video on screen, it's been 4 days now that the screen hasn't turned on.
による
Also, when connected to a video-out adapter, the external display works.
による
表示する 7 他のコメントを
コメントを追加
Hi there , pls help me to locate L8300 so I can check voltage level also pls help me how to check if the lcd display driver chip is ok or not what voltage I should read and how also pin diagram for that chip. Can I check F7700 fuse status while stil soldered on board, pls help my backlight is not light up after I removed the display cable while still system on . Sorry pls help
この回答は役に立ちましたか?
スコア 0
コメントを追加
i cant get 5v lcdbklt_fet_drv_r or c7741 can you help me
この回答は役に立ちましたか?
スコア 0
コメント:
i have backlight problem i changed u7700 and q7700 no backlight
による
コメントを追加
回答を追加する
Oscar Romero さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,405
